Saltar al contenido principal
Acer Swift 3 2022 Touchpad Replacement
Qué necesitas
  1. Acer Swift 3 2022 Touchpad Replacement, Bottom Cover: paso 1, imagen 1 de 1
    • Be sure to power off the laptop before starting.
    • Flip the device over so the bottom panel is facing up.
  2. Acer Swift 3 2022 Touchpad Replacement: paso 2, imagen 1 de 2 Acer Swift 3 2022 Touchpad Replacement: paso 2, imagen 2 de 2
    • Remove the eleven 5 mm screws from the back of the device using a TR6 Torx screwdriver.
  3. Acer Swift 3 2022 Touchpad Replacement: paso 3, imagen 1 de 1
    • Use the iFixit opening tool to pry open the back of the device.
    • Remove the bottom cover from the laptop.
  4. Acer Swift 3 2022 Touchpad Replacement, Battery: paso 4, imagen 1 de 2 Acer Swift 3 2022 Touchpad Replacement, Battery: paso 4, imagen 2 de 2
    • Peel back the strip of black tape.
  5. Acer Swift 3 2022 Touchpad Replacement: paso 5, imagen 1 de 3 Acer Swift 3 2022 Touchpad Replacement: paso 5, imagen 2 de 3 Acer Swift 3 2022 Touchpad Replacement: paso 5, imagen 3 de 3
    • Unplug the group of wires by pulling the white plastic piece towards yourself.
    • Be careful, this piece can be easily damaged.
  6. Acer Swift 3 2022 Touchpad Replacement: paso 6, imagen 1 de 2 Acer Swift 3 2022 Touchpad Replacement: paso 6, imagen 2 de 2
    • Remove the two 5 mm screws on the sides of the battery using a TR6 Torx screwdriver.
  7. Acer Swift 3 2022 Touchpad Replacement: paso 7, imagen 1 de 1
    • Remove battery.
  8. Acer Swift 3 2022 Touchpad Replacement, Touchpad: paso 8, imagen 1 de 1
    • Before disassembly, place a sheet of paper or cloth material between the touchpad and the screen.
  9. Acer Swift 3 2022 Touchpad Replacement: paso 9, imagen 1 de 2 Acer Swift 3 2022 Touchpad Replacement: paso 9, imagen 2 de 2
    • Using the iFixit opening tool, flip up the black plastic retaining flap holding the white ribbon cable.
    • It's like popping open a coke can!
  10. Acer Swift 3 2022 Touchpad Replacement: paso 10, imagen 1 de 1
    • Pull the ribbon cable out.
  11. Acer Swift 3 2022 Touchpad Replacement: paso 11, imagen 1 de 2 Acer Swift 3 2022 Touchpad Replacement: paso 11, imagen 2 de 2
    • Pull the black flap of film up to identify the two screws.
    • Remove the two 2 mm screws using a JIS #1 screwdriver.
  12. Acer Swift 3 2022 Touchpad Replacement: paso 12, imagen 1 de 1
    • Take out the touchpad.
Conclusión
2 personas más completaron esta guía.
Anna Miller
Miembro Desde 09/26/22
888 Reputación
6 Guías creadas
Equipo
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 18
Ultimos 30 días: 59
Todo El Tiempo: 1,259
