Saltar al contenido principal
Acer Swift 3 2022 Screen Replacement
Qué necesitas
  1. Acer Swift 3 2022 Screen Replacement, Bottom Cover: paso 1, imagen 1 de 1
    • Be sure to power off the laptop before starting.
    • Flip the device over so the bottom panel is facing up.
  2. Acer Swift 3 2022 Screen Replacement: paso 2, imagen 1 de 2 Acer Swift 3 2022 Screen Replacement: paso 2, imagen 2 de 2
    • Remove the eleven 5 mm screws from the back of the device using a TR6 Torx screwdriver.
  3. Acer Swift 3 2022 Screen Replacement: paso 3, imagen 1 de 1
    • Use the iFixit opening tool to pry open the back of the device.
    • Remove the bottom cover from the laptop.
  4. Acer Swift 3 2022 Screen Replacement, How to Unplug the Battery: paso 4, imagen 1 de 3 Acer Swift 3 2022 Screen Replacement, How to Unplug the Battery: paso 4, imagen 2 de 3 Acer Swift 3 2022 Screen Replacement, How to Unplug the Battery: paso 4, imagen 3 de 3
    • Peel back the strip of black tape.
  5. Acer Swift 3 2022 Screen Replacement: paso 5, imagen 1 de 2 Acer Swift 3 2022 Screen Replacement: paso 5, imagen 2 de 2
    • Unplug the group of wires by pulling the white plastic piece towards yourself.
    • Be careful, this piece can be easily damaged.
  6. Acer Swift 3 2022 Screen Replacement, Screen: paso 6, imagen 1 de 3 Acer Swift 3 2022 Screen Replacement, Screen: paso 6, imagen 2 de 3 Acer Swift 3 2022 Screen Replacement, Screen: paso 6, imagen 3 de 3
    • Remove the EDP Cable located on the top right by pushing away from you.
  7. Acer Swift 3 2022 Screen Replacement: paso 7, imagen 1 de 3 Acer Swift 3 2022 Screen Replacement: paso 7, imagen 2 de 3 Acer Swift 3 2022 Screen Replacement: paso 7, imagen 3 de 3
    • Remove the four 4.5 mm screws on the metal plates located on the top left and right hand corner using the JIS #1 screwdriver.
    • Flip up the metal plates.
    • The metal plates will be tight/hard to move.
  8. Acer Swift 3 2022 Screen Replacement: paso 8, imagen 1 de 1
    • Open computer to a 90 degree angle by lifting the keyboard and sliding it out.
    • Place keyboard to the side so the screen is face up and the only thing in front of you.
  9. Acer Swift 3 2022 Screen Replacement: paso 9, imagen 1 de 3 Acer Swift 3 2022 Screen Replacement: paso 9, imagen 2 de 3 Acer Swift 3 2022 Screen Replacement: paso 9, imagen 3 de 3
    • Insert the spudger between the computer screen and the black bezel.
    • Slide around the whole perimeter of screen.
    • Peel the bezel off.
  10. Acer Swift 3 2022 Screen Replacement: paso 10, imagen 1 de 3 Acer Swift 3 2022 Screen Replacement: paso 10, imagen 2 de 3 Acer Swift 3 2022 Screen Replacement: paso 10, imagen 3 de 3
    • Disconnect the other end of the EDP Cable located next to the camera with the spudger.
  11. Acer Swift 3 2022 Screen Replacement: paso 11, imagen 1 de 3 Acer Swift 3 2022 Screen Replacement: paso 11, imagen 2 de 3 Acer Swift 3 2022 Screen Replacement: paso 11, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Using the curved, fine-tipped tweezers, unstick the tape from the top of the case.
    • Once the tape is unstuck, pinch it with the tweezers and pull in the opposite direction.
    • Repeat on the other side.
    • The tape will stretch. You might have to regrip it.
    • You may only do this once. The tape will no longer be effective.
  12. Acer Swift 3 2022 Screen Replacement: paso 12, imagen 1 de 1
    • Remove screen.
    • There will be some wires connected to the bottom of the screen. Pull them out carefully with the screen.
Conclusión
Anna Miller
Miembro Desde 09/26/22
831 Reputación
6 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 15
Ultimos 30 días: 106
Todo El Tiempo: 2,502
