Saltar al contenido principal
Acer Iconia A110 Battery Replacement
Qué necesitas
  1. Acer Iconia A110 Battery Replacement, Battery: paso 1, imagen 1 de 2 Acer Iconia A110 Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Before taking apart your tablet, make sure the device is powered off.
    • Pry open the right side of case with the plastic opening tool. If necessary, keep a tool lodged into the side to keep the case from closing.
    • During this process, the volume button and/or power button may fall out.
  2. Acer Iconia A110 Battery Replacement: paso 2, imagen 1 de 3 Acer Iconia A110 Battery Replacement: paso 2, imagen 2 de 3 Acer Iconia A110 Battery Replacement: paso 2, imagen 3 de 3
    • Pry open the left side of the case with a plastic opening tool. The backside of the tablet should now separate completely from the front.
  3. Acer Iconia A110 Battery Replacement: paso 3, imagen 1 de 3 Acer Iconia A110 Battery Replacement: paso 3, imagen 2 de 3 Acer Iconia A110 Battery Replacement: paso 3, imagen 3 de 3
    • Using the plastic opening tool and spudger, carefully pry up the battery from the case.
    • You should hear the adhesive ripping as you do this.
    • Once the battery is no longer adhered to the case, detach the dongle that connects the battery to the motherboard.
Conclusión
3 personas más completaron esta guía.
Andrea
Miembro Desde 04/14/14
757 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 3-42, Maness Spring 2014 Miembro de Cal Poly, Team 3-42, Maness Spring 2014
CPSU-MANESS-S14S3G42
4 Miembros
5 Guías creadas
Un comentario
Where can you purchase the battery for acer iconia tab a110?
redd4167 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 12
Todo El Tiempo: 11,246
