Saltar al contenido principal
Acer Chromebook CB3-111-C670 Battery Replacement
Qué necesitas
  1. Acer Chromebook CB3-111-C670 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Be sure to have completely shut down the device before attempting to open it.
    • Remove the twelve Phillips #00 screws.
  2. Acer Chromebook CB3-111-C670 Battery Replacement: paso 2, imagen 1 de 1
    • Insert a prying tool in between the top and bottom pieces of the laptop case to pry them apart but *do not remove the lower case*.
    • Carefully open the case to the left to avoid ripping the interior ribbon cable.
  3. Acer Chromebook CB3-111-C670 Battery Replacement: paso 3, imagen 1 de 1
    • Pull the battery connector cable towards the battery to disconnect it.
  4. Acer Chromebook CB3-111-C670 Battery Replacement: paso 4, imagen 1 de 1
    • Remove the battery.
Conclusión
6 personas más completaron esta guía.
Tony
Miembro Desde 01/20/16
459 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 10-5, Remmell Spring 2016 Miembro de USF Tampa, Team 10-5, Remmell Spring 2016
USFT-REMMELL-S16S10G5
3 Miembros
8 Guías creadas
Un comentario
Off topic and everything but how can i fix the audio jack? My audio jack is so worn it wont play sound
Daichi Potato - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 17
Todo El Tiempo: 4,134
