Saltar al contenido principal
Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement
Qué necesitas
  1. Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement, Back Cover: paso 1, imagen 1 de 3 Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement, Back Cover: paso 1, imagen 2 de 3 Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement, Back Cover: paso 1, imagen 3 de 3
    • Remove the two 6mm JIS #0 screws from either side of the hinges.
  2. Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement: paso 2, imagen 1 de 1
    • Remove the eight 4mm JIS #0 screws from the back cover.
  3. Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement: paso 3, imagen 1 de 2 Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement: paso 3, imagen 2 de 2
    • Insert an opening pick between the back panel and the sides of the computer to begin lifting the back off.
    • There are several clips holding the cover in place.
    • After the sides have been lifted, use the opening tool to finish opening the back cover.
  4. Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement: paso 4, imagen 1 de 1
    • Lift off the back cover.
  5. Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement, Battery: paso 5, imagen 1 de 3 Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement, Battery: paso 5, imagen 2 de 3 Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement, Battery: paso 5, imagen 3 de 3
    • Remove the two JIS #0 screws that connect the battery to the rest of the laptop.
  6. Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement: paso 6, imagen 1 de 2 Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement: paso 6, imagen 2 de 2
    • Pull the white tab connected to the battery out of the black tab that connects to the motherboard.
    • It is extremely important that this is done carefully and slowly to avoid causing damage to the motherboard.
  7. Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement: paso 7, imagen 1 de 1
    • Lift the battery out gently.
  8. Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement, Trackpad: paso 8, imagen 1 de 1
    • Remove the strip of tape that secures the motherboard connector to the track pad.
  9. Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement: paso 9, imagen 1 de 1
    • Unclip the motherboard connector from the track pad.
  10. Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement: paso 10, imagen 1 de 1
    • Remove the strip of electrical tape from across the top of the track pad.
  11. Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement: paso 11, imagen 1 de 1
    • Remove three 4 mm JIS #0 screws from the top of the track pad.
  12. Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement: paso 12, imagen 1 de 1
    • Lift the laptop base and the track pad will come out from the front of the laptop.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 6
Ultimos 30 días: 20
Todo El Tiempo: 768
