Introducción
If your Acer Chromebook 14 CB3-431-C3WS does not turn on when the power button is pushed, doesn’t remain charged or usable unless connected to an external power source you may need to replace the battery.
Try following this troubleshooting guide before attempting to replace the battery to see if you can find an easier solution.
Before beginning, make sure that your laptop is completely turned off, and disconnected from any external power sources.
Qué necesitas
Remove the two JIS #0 screws that connect the battery to the rest of the laptop.
8 personas más completaron esta guía.
3 comentarios
Bonjour vous vendez les batteries CB3-431
Vous vendez les batteries CB3-431
Instructions were great. Battery installation complete! I was very glad to find step by step instructions instead of a video. The Chromebook powered up successfully. Now waiting for it to charge. Thank you!
