Introducción
How to replace a faulty motherboard in your Acer Aspire V5-473P-5602
The motherboard is the brain of the computer, and a faulty motherboard is a brain-dead system. Fans and drives may work if the motherboard is dead, but most of the time, nothing happens when you turn on the power. A number of things can cause the problem such as a burnt-out graphic chip or a damaged power jack. Check the power supply before disassembling your motherboard. It may be as simple as a bad power connection. If it does not work after using another power source, the motherboard is more than likely faulty.
- Keep yourself grounded to avoid shocking your components by using an anti-static mat OR an anti-static wristband.
- Carpet creates static, so if you do NOT have an anti-static mat or wristband, wear rubber sole shoes while standing on a hard surface floor.
- All computer components should remain in the anti-static bags they came in until ready for installation.
- Complete all 14 steps in order.
- Taking photos as you complete each step will help you keep track of where each component should be.
Qué necesitas
Flip the laptop over so the back panel is facing upwards.
Use the Phillips #0 screwdriver to remove seventeen 2.5mm screws.
Remove the back panel from the laptop using an iFixit opening tool.
Remove the ten Phillips #0 screws that attach the motherboard to the keyboard.
Una persona más ha completado esta guía.
