Saltar al contenido principal
Acer Aspire R7 Battery Replacement
Qué necesitas
  1. Acer Aspire R7 Battery Replacement, Cover: paso 1, imagen 1 de 1
    • Shut down the laptop and disconnect the power cord.
    • Failing to disconnect or shut down the laptop could result in damage to the laptop or a shock hazard.
    • Turn the laptop over.
  2. Acer Aspire R7 Battery Replacement: paso 2, imagen 1 de 3 Acer Aspire R7 Battery Replacement: paso 2, imagen 2 de 3 Acer Aspire R7 Battery Replacement: paso 2, imagen 3 de 3
    • Remove seven 10 mm T7 screws.
    • Remove four 6 mm T7 screws.
    • Use the blue plastic opening tool to carefully remove both rubber pads which cover the four remaining screws.
    • Remove the remaining four 10 mm T7 screws.
  3. Acer Aspire R7 Battery Replacement: paso 3, imagen 1 de 1
    • Carefully lift the cover upwards.
    • If the cover seems stuck, use a spudger tool to pry the sides.
  4. Acer Aspire R7 Battery Replacement, Battery: paso 4, imagen 1 de 2 Acer Aspire R7 Battery Replacement, Battery: paso 4, imagen 2 de 2
    • Locate the battery ribbon connector
    • Remove the ribbon cable attaching the battery to the motherboard by carefully pulling it outwards
    • When using the spudger be careful around the motherboard as it can easily be damaged
  5. Acer Aspire R7 Battery Replacement: paso 5, imagen 1 de 3 Acer Aspire R7 Battery Replacement: paso 5, imagen 2 de 3 Acer Aspire R7 Battery Replacement: paso 5, imagen 3 de 3
    • Remove the three 4.5mm #00 Phillips screws attaching the battery to the motherboard
    • Push the 4 retaining clips away from the battery
    • Carefully lift the battery from the motherboard
Conclusión
12 personas más completaron esta guía.
F Fernandez
Miembro Desde 01/13/15
435 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 3-4, Hickman Winter 2015 Miembro de USF Tampa, Team 3-4, Hickman Winter 2015
USFT-HICKMAN-W15S3G4
4 Miembros
7 Guías creadas
6 comentarios
What is the battery reference for replacement ?
skalpinou - Contestar
which battery model do I purchase for replacing on an Acer Aspire R?
Eddie - Contestar
hey how do you want då sel it for
Alex santos - Contestar
super tuto
Thanks
P.S : A have add a short comment on step 2.
Bests regards
Anthymoine - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 11
Ultimos 30 días: 39
Todo El Tiempo: 41,171
