Saltar al contenido principal
Acer Aspire One P1VE6 Individual Key Replacement
Qué necesitas
  1. Acer Aspire One P1VE6 Individual Key Replacement, Individual Key: paso 1, imagen 1 de 1
    • Turn the netbook off and open it.
  2. Acer Aspire One P1VE6 Individual Key Replacement: paso 2, imagen 1 de 1
    • Use plastic opening tool to remove the key.
  3. Acer Aspire One P1VE6 Individual Key Replacement: paso 3, imagen 1 de 1
    • Push working key back into place until it clicks. Make sure key is in correct position.
Linea de Meta
Una persona más ha completado esta guía.
1Guía Comentario
This article is linked under the "keys not working" section of a trouble shooting guide (Acer Aspire One 722 (P1VE6) Troubleshooting).
It's quite unlikely that just replacing the keycap will make the corresponding keystrokes register again. That would most likely require replacing the underlying microswitch, which is basically impossible.
rjvbertin - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 10
Todo El Tiempo: 1,265
