Saltar al contenido principal
Acer Aspire One 722 Battery Replacement
  1. Acer Aspire One 722 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Power down the netbook by pressing the power button on the top left corner.
  2. Acer Aspire One 722 Battery Replacement: paso 2, imagen 1 de 1
    • Close the netbook and flip it over so that the back is facing up.
  3. Acer Aspire One 722 Battery Replacement: paso 3, imagen 1 de 1
    • Slide the button below the battery to the right while simultaneously pulling the battery out.
  4. Acer Aspire One 722 Battery Replacement: paso 4, imagen 1 de 2 Acer Aspire One 722 Battery Replacement: paso 4, imagen 2 de 2
    • If necessary, remove the old battery and replace it with a new one.
  5. Acer Aspire One 722 Battery Replacement: paso 5, imagen 1 de 1
    • Check the thin grooves on the side of the battery entry and line the replacement battery up to the grooves.
Conclusión
12 personas más completaron esta guía.
Equipo
UMass Dartmouth, Team 5-6, Gulbrandsen Fall 2015 Miembro de UMass Dartmouth, Team 5-6, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G6
3 Miembros
10 Guías creadas
4 comentarios
First rate easy to understand completed in less than a minute.many thanks
Alan Fowler - Contestar
I find myself computer savvy. These steps jarred my memory. They were perfect.
scolan910 - Contestar
Thank you, you are a hero of 2021.
Athirah siagian - Contestar
Thank you. Simple, yes, but a little encouragement always helps.
Wade Stanfill - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 10
Ultimos 30 días: 49
Todo El Tiempo: 12,342
