Saltar al contenido principal
Acer Aspire E5-571 Keyboard Replacement
Qué necesitas
  1. Acer Aspire E5-571 Keyboard Replacement, Battery: paso 1, imagen 1 de 1
    • Make sure the laptop is shut down.
    • Flip the laptop upside down. Rotate it so the battery faces you.
  2. Acer Aspire E5-571 Keyboard Replacement: paso 2, imagen 1 de 1
    • Place the pointed end of a spudger into the battery lock. Slide the battery lock to the left using the spudger. A "click" sound will accompany the release of the battery.
  3. Acer Aspire E5-571 Keyboard Replacement: paso 3, imagen 1 de 1
    • Pull the battery towards you to remove it from the laptop.
  4. Acer Aspire E5-571 Keyboard Replacement, Keyboard: paso 4, imagen 1 de 1
    • Remove all eighteen 8 mm screws with a Phillips #0 screwdriver.
  5. Acer Aspire E5-571 Keyboard Replacement: paso 5, imagen 1 de 3 Acer Aspire E5-571 Keyboard Replacement: paso 5, imagen 2 de 3 Acer Aspire E5-571 Keyboard Replacement: paso 5, imagen 3 de 3
    • Carefully pry apart the clips holding the keyboard in place by moving a metal spudger along the seam.
    • Be careful not to break the plastic clips. Do not remove the keyboard until told to do so.
  6. Acer Aspire E5-571 Keyboard Replacement: paso 6, imagen 1 de 2 Acer Aspire E5-571 Keyboard Replacement: paso 6, imagen 2 de 2
    • Carefully flip up the white hinge. Then, detach the three ZIF ribbons connected to the motherboard.
    • Remove the panel with the keyboard and the touchpad.
Conclusión
9 personas más completaron esta guía.
daniel sawyer
Miembro Desde 08/23/15
2,566 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 4-2, Meier Fall 2015 Miembro de USF Tampa, Team 4-2, Meier Fall 2015
USFT-MEIER-F15S4G2
3 Miembros
5 Guías creadas
4 comentarios
keyboard cable is a b$%*h
shrs - Contestar
can you explain how to remove the keyboard and attach the new one to the whole top
christhesoccerkid - Contestar
keyboard cable is indeed a b$%*h, but you will get there with the patience of a zen master
here's a video that shows the extra steps of remo9ving and replacing keyboard: https://www.youtube.com/watch?v=DpawPQrq...
tom - Contestar
I'm only 13 and it was easy to get to the dvd-rw drive and unjam it, little hands made the keyboard cable a breeze.
tha B-BOY - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 39
Todo El Tiempo: 12,206
