Saltar al contenido principal
Abask J05 Motherboard Replacement
Qué necesitas
  1. Abask J05 Motherboard Replacement, Front Case: paso 1, imagen 1 de 2 Abask J05 Motherboard Replacement, Front Case: paso 1, imagen 2 de 2
    • Gently press on the SD card with a fingernail until it clicks.
    • Release, then remove the card.
  2. Abask J05 Motherboard Replacement: paso 2, imagen 1 de 1
    • Remove the 5 mm screw from the side of the device next to the suction cup dock with a Phillips #00 screwdriver.
  3. Abask J05 Motherboard Replacement: paso 3, imagen 1 de 2 Abask J05 Motherboard Replacement: paso 3, imagen 2 de 2
    • Remove the two 8 mm screws from opposite sides of the screen with a Phillips #00 precision screwdriver.
  4. Abask J05 Motherboard Replacement: paso 4, imagen 1 de 2 Abask J05 Motherboard Replacement: paso 4, imagen 2 de 2
    • Gently lift the screen.
    • Push up on the interior camera portion of the device. It should pop out of the socket. Being careful to keep the wires attached, set it to the side.
  5. Abask J05 Motherboard Replacement: paso 5, imagen 1 de 2 Abask J05 Motherboard Replacement: paso 5, imagen 2 de 2
    • Reach into the device with a spudger to release the top two snap joints keeping the end cap attached one at a time until the front face lifts off.
    • Be careful not to touch the screen.
    • Repeat the process with the two remaining snap joints.
  6. Abask J05 Motherboard Replacement, Screen: paso 6, imagen 1 de 2 Abask J05 Motherboard Replacement, Screen: paso 6, imagen 2 de 2
    • Remove the two 7 mm screws on the side of the motherboard with a Phillips #00 screwdriver.
    • Slowly pull up on each corner of the motherboard, stopping when the corner pops loose of the anchor.
    • Repeat the process with each corner before slowly pulling up on the board to detach the glue on the underside.
  7. Abask J05 Motherboard Replacement: paso 7, imagen 1 de 3 Abask J05 Motherboard Replacement: paso 7, imagen 2 de 3 Abask J05 Motherboard Replacement: paso 7, imagen 3 de 3
    • Carefully flip over the motherboard, being mindful of the wires.
    • Remove the two 5mm screws on the underside of the motherboard with a Phillips #000 screwdriver.
  8. Abask J05 Motherboard Replacement: paso 8, imagen 1 de 2 Abask J05 Motherboard Replacement: paso 8, imagen 2 de 2
    • Follow the golden ribbon from the screen to the screen dock. Push the two small black stubs on either side of the dock away from the dock until it pops loose.
    • Remove the ribbon and the small plastic piece from the dock.
  9. Abask J05 Motherboard Replacement: paso 9, imagen 1 de 2 Abask J05 Motherboard Replacement: paso 9, imagen 2 de 2
    • Gently pull up on each corner of the white screen piece until the adhesive comes loose.
    • Remove the screen fully from its holder.
  10. Abask J05 Motherboard Replacement, Motherboard: paso 10, imagen 1 de 3 Abask J05 Motherboard Replacement, Motherboard: paso 10, imagen 2 de 3 Abask J05 Motherboard Replacement, Motherboard: paso 10, imagen 3 de 3
    • Desolder the red wire attached to the motherboard.
  11. Abask J05 Motherboard Replacement: paso 11, imagen 1 de 2 Abask J05 Motherboard Replacement: paso 11, imagen 2 de 2
    • Detach the ribbon cable connecting the motherboard to the rest of the device.
  12. Abask J05 Motherboard Replacement: paso 12, imagen 1 de 2 Abask J05 Motherboard Replacement: paso 12, imagen 2 de 2
    • Desolder all four wires connected to the motherboard.
  13. Abask J05 Motherboard Replacement: paso 13, imagen 1 de 1
    • Remove the motherboard from the device.
Conclusión
To reassemble your device, follow these instructions in reverse order. (Note: When doing the steps in reverse order, do not do Step 5. Instead, place the front face of the device back on the main body before lining up the endcap, ensuring proper orientation with the SD card slot, and push in until you hear all four snap joints snap into place.)
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 2
Todo El Tiempo: 59
