Saltar al contenido principal
ASUS X502CA Motherboard Replacement
Qué necesitas
  1. ASUS X502CA Motherboard Replacement, Palm Rest with Keyboard and Touch Pad: paso 1, imagen 1 de 1
    • Use the Phillips #00 screwdriver to remove the seven 90mm screws.
    • Use the Phillips #00 screwdriver to remove the four 50mm screws.
  2. ASUS X502CA Motherboard Replacement: paso 2, imagen 1 de 1
    • Next, use the plastic opening tool to carefully pop off the keyboard cover panel.
    • Be cautious when pulling off the cover because there are cables you will have to disconnect before completely removing the panel.
  3. ASUS X502CA Motherboard Replacement: paso 3, imagen 1 de 2 ASUS X502CA Motherboard Replacement: paso 3, imagen 2 de 2
    • Lift palm rest and unplug keyboard cable and touchpad cable using tweezers. After these two cables have been unplugged you can remove the keyboard cover panel.
  4. ASUS X502CA Motherboard Replacement: paso 4, imagen 1 de 2 ASUS X502CA Motherboard Replacement: paso 4, imagen 2 de 2
    • Lift Palm Rest away.
    • Replace with new palm rest.
  5. ASUS X502CA Motherboard Replacement, Hard Drive: paso 5, imagen 1 de 2 ASUS X502CA Motherboard Replacement, Hard Drive: paso 5, imagen 2 de 2
    • Remove the four 5mm screws that attach the hard drive bracket using the Phillips #0 screwdriver.
  6. ASUS X502CA Motherboard Replacement: paso 6, imagen 1 de 2 ASUS X502CA Motherboard Replacement: paso 6, imagen 2 de 2
    • Lift the hard drive and attached bracket up and out.
  7. ASUS X502CA Motherboard Replacement: paso 7, imagen 1 de 3 ASUS X502CA Motherboard Replacement: paso 7, imagen 2 de 3 ASUS X502CA Motherboard Replacement: paso 7, imagen 3 de 3
    • Remove the four 5mm Phillips #0 screws attaching the bracket to the hard drive.
    • There are 2 screws on each side.
  8. ASUS X502CA Motherboard Replacement, LED Board: paso 8, imagen 1 de 3 ASUS X502CA Motherboard Replacement, LED Board: paso 8, imagen 2 de 3 ASUS X502CA Motherboard Replacement, LED Board: paso 8, imagen 3 de 3
    • Use the plastic opening tool to flip up the small clamp and pull out the ribbon cable.
  9. ASUS X502CA Motherboard Replacement: paso 9, imagen 1 de 2 ASUS X502CA Motherboard Replacement: paso 9, imagen 2 de 2
    • Use 1 or 2 plastic opening tools to push down the small black plastic clips.
    • Pull the board up and out.
  10. ASUS X502CA Motherboard Replacement, Left I/O Board: paso 10, imagen 1 de 2 ASUS X502CA Motherboard Replacement, Left I/O Board: paso 10, imagen 2 de 2
    • Locate the I/O board on the left of the computer. Using the Phillips #0 screwdriver, unscrew the three 5mm screws to unhinge the screen, which will free the board allowing it to be removed and replaced.
    • Be careful with handling your computer while one side is unhinged; mishandling or over pressuring the other hinge could cause damage to it or the screen.
  11. ASUS X502CA Motherboard Replacement: paso 11, imagen 1 de 2 ASUS X502CA Motherboard Replacement: paso 11, imagen 2 de 2
    • Unplug the power strip connecting to the motherboard with your fingers or plastic opening tool.
    • Make sure the power strip is disconnected before pulling the board out.
  12. ASUS X502CA Motherboard Replacement: paso 12, imagen 1 de 2 ASUS X502CA Motherboard Replacement: paso 12, imagen 2 de 2
    • Slightly pull the unhinged screen up to free the board and remove it.
  13. ASUS X502CA Motherboard Replacement, Battery: paso 13, imagen 1 de 1
    • Next, locate the battery in the front of laptop (closest to you).
  14. ASUS X502CA Motherboard Replacement: paso 14, imagen 1 de 1
    • Unplug the battery from the laptop in the upper right hand corner of the battery using tweezers.
    • If battery is not unplugged, motherboard may shock you.
  15. ASUS X502CA Motherboard Replacement: paso 15, imagen 1 de 2 ASUS X502CA Motherboard Replacement: paso 15, imagen 2 de 2
    • Use the Phillips #00 Screwdriver to carefully remove the 6 screws holding the battery in place.
    • Once you have removed all six screws carefully lift the battery out and dispose.
    • Each screw is 50 mm in length and 15 mm in diameter.
  16. ASUS X502CA Motherboard Replacement, Motherboard: paso 16, imagen 1 de 2 ASUS X502CA Motherboard Replacement, Motherboard: paso 16, imagen 2 de 2
    • Use the Phillips #0 screwdriver to remove the last five 5mm screws holding the motherboard down.
    • These screws will be marked by diamonds next to the screw holes.
  17. ASUS X502CA Motherboard Replacement: paso 17, imagen 1 de 2 ASUS X502CA Motherboard Replacement: paso 17, imagen 2 de 2
    • Use the plastic opening tool to unclip the two wires from the Wi-Fi card that are connected to the motherboard.
  18. ASUS X502CA Motherboard Replacement: paso 18, imagen 1 de 3 ASUS X502CA Motherboard Replacement: paso 18, imagen 2 de 3 ASUS X502CA Motherboard Replacement: paso 18, imagen 3 de 3
    • Flip the motherboard over and use the plastic opening tool to unplug the black and red wires from the motherboard.
  19. ASUS X502CA Motherboard Replacement: paso 19, imagen 1 de 1
    • Pull up on the motherboard and take it out.
Conclusión
Una persona más ha completado esta guía.
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 2
Todo El Tiempo: 628
