Introducción
It is possible your Asus's I/O board has stopped working properly due to electrical damage or degradation over time. A replacement board may be the proper fix, after purchasing a new board follow the guide below to replace the old I/O board.
Qué necesitas
Use the Phillips #00 screwdriver to remove the seven 90mm screws.
Use the Phillips #00 screwdriver to remove the four 50mm screws.
Locate the I/O board on the left of the computer. Using the Phillips #0 screwdriver, unscrew the three 5mm screws to unhinge the screen, which will free the board allowing it to be removed and replaced.
