Saltar al contenido principal
ASUS X502CA Hard Drive Replacement
Qué necesitas
  1. ASUS X502CA Hard Drive Replacement, Palm Rest with Keyboard and Touch Pad: paso 1, imagen 1 de 1
    • Use the Phillips #00 screwdriver to remove the seven 90mm screws.
    • Use the Phillips #00 screwdriver to remove the four 50mm screws.
  2. ASUS X502CA Hard Drive Replacement: paso 2, imagen 1 de 1
    • Next, use the plastic opening tool to carefully pop off the keyboard cover panel.
    • Be cautious when pulling off the cover because there are cables you will have to disconnect before completely removing the panel.
  3. ASUS X502CA Hard Drive Replacement: paso 3, imagen 1 de 2 ASUS X502CA Hard Drive Replacement: paso 3, imagen 2 de 2
    • Lift palm rest and unplug keyboard cable and touchpad cable using tweezers. After these two cables have been unplugged you can remove the keyboard cover panel.
  4. ASUS X502CA Hard Drive Replacement: paso 4, imagen 1 de 2 ASUS X502CA Hard Drive Replacement: paso 4, imagen 2 de 2
    • Lift Palm Rest away.
    • Replace with new palm rest.
  5. ASUS X502CA Hard Drive Replacement, Hard Drive: paso 5, imagen 1 de 2 ASUS X502CA Hard Drive Replacement, Hard Drive: paso 5, imagen 2 de 2
    • Remove the four 5mm screws that attach the hard drive bracket using the Phillips #0 screwdriver.
  6. ASUS X502CA Hard Drive Replacement: paso 6, imagen 1 de 2 ASUS X502CA Hard Drive Replacement: paso 6, imagen 2 de 2
    • Lift the hard drive and attached bracket up and out.
  7. ASUS X502CA Hard Drive Replacement: paso 7, imagen 1 de 3 ASUS X502CA Hard Drive Replacement: paso 7, imagen 2 de 3 ASUS X502CA Hard Drive Replacement: paso 7, imagen 3 de 3
    • Remove the four 5mm Phillips #0 screws attaching the bracket to the hard drive.
    • There are 2 screws on each side.
Conclusión
Una persona más ha completado esta guía.
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 4
Todo El Tiempo: 410
