Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
This guide will show you on how to replace the display screen on your laptop.
Only replace the screen if it has been physically damaged (e.g. cracks). If there are any other problems, such as the touch screen not functioning or freezing, then this guide will not help you resolve those issues. Instead, view the troubleshooting guide to find a more appropriate solution.
Partes
No se especificaron partes.
  1. Unscrew the (10) screws on the bottom of the computer chassis using the JIS #0 screwdriver.
    • Unscrew the (10) screws on the bottom of the computer chassis using the JIS #0 screwdriver.
  2. Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs. Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
    • Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
  3. ABRIR TODAS LAS PESTAÑAS
    Kits de actualización de RAM para Mac
    Compra kits
    Suficiente RAM
    para todas las pestañas
    Compra kits
  4. Remove the (6) six screws attaching the battery to the frame using the JIS #0 screwdriver. Use the black plastic spudger to remove the battery from the device. Use the black plastic spudger to remove the battery from the device.
    • Remove the (6) six screws attaching the battery to the frame using the JIS #0 screwdriver.
    • Use the black plastic spudger to remove the battery from the device.
  5. Gently take the battery out of the laptop, making sure that all wires connecting to it are disconnected. Gently take the battery out of the laptop, making sure that all wires connecting to it are disconnected. Gently take the battery out of the laptop, making sure that all wires connecting to it are disconnected.
    • Gently take the battery out of the laptop, making sure that all wires connecting to it are disconnected.
  6. Remove the screws connecting the display to the laptop. Furthermore, detach the wires connecting the screen to the motherboard.
    • Remove the screws connecting the display to the laptop. Furthermore, detach the wires connecting the screen to the motherboard.
Conclusión
Equipo
USF Tampa, Team S5-G1, Walkup Fall 2017 Miembro de USF Tampa, Team S5-G1, Walkup Fall 2017
USFT-WALKUP-F17S5G1
4 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 504
