Saltar al contenido principal
ASUS TUF Gaming FX505DY Solid State Drive Replacement
Qué necesitas
  1. ASUS TUF Gaming FX505DY Solid State Drive Replacement, Back Case: paso 1, imagen 1 de 1
    • Turn off the laptop.
    • Disconnect the charging cable.
    • Failure to disconnect the charging cable and power down the computer could result in personal or property damage.
    • Flip the laptop so the back is facing up.
  2. ASUS TUF Gaming FX505DY Solid State Drive Replacement: paso 2, imagen 1 de 2 ASUS TUF Gaming FX505DY Solid State Drive Replacement: paso 2, imagen 2 de 2
    • Use a Phillips #1 screwdriver to remove the five 6 mm screws that secure the back panel.
    • Use the same screwdriver to remove the six 13 mm screws securing the back panel.
  3. ASUS TUF Gaming FX505DY Solid State Drive Replacement: paso 3, imagen 1 de 2 ASUS TUF Gaming FX505DY Solid State Drive Replacement: paso 3, imagen 2 de 2
    • Insert the plastic opening tool at a corner and pry up along the edges, leaving the back side with the hinges for last.
    • Do not insert the opening tool too far into the laptop to avoid damaging internal components.
  4. ASUS TUF Gaming FX505DY Solid State Drive Replacement: paso 4, imagen 1 de 2 ASUS TUF Gaming FX505DY Solid State Drive Replacement: paso 4, imagen 2 de 2
    • Gently lift up the back panel to release any remaining clips on the side with the hinges and remove the panel.
  5. ASUS TUF Gaming FX505DY Solid State Drive Replacement, Solid State Drive: paso 5, imagen 1 de 2 ASUS TUF Gaming FX505DY Solid State Drive Replacement, Solid State Drive: paso 5, imagen 2 de 2
    • Remove the two 3 mm screws holding the solid state drive and its foil wrap in place using a Phillips #1 screwdriver.
    • The drive will pop up at an angle.
  6. ASUS TUF Gaming FX505DY Solid State Drive Replacement: paso 6, imagen 1 de 3 ASUS TUF Gaming FX505DY Solid State Drive Replacement: paso 6, imagen 2 de 3 ASUS TUF Gaming FX505DY Solid State Drive Replacement: paso 6, imagen 3 de 3
    • Slide the foil wrap off of the drive.
  7. ASUS TUF Gaming FX505DY Solid State Drive Replacement: paso 7, imagen 1 de 2 ASUS TUF Gaming FX505DY Solid State Drive Replacement: paso 7, imagen 2 de 2
    • Remove the solid state drive by pulling it at an angle from the motherboard.
Conclusión
Una persona más ha completado esta guía.
Benyamin Claxton
Miembro Desde 03/27/22
1,010 Reputación
5 Guías creadas
Equipo
UMass Dartmouth, Team 2-4, Mellen Spring 2022 Miembro de UMass Dartmouth, Team 2-4, Mellen Spring 2022
UMASSD-MELLEN-S22S2G4
Miembros de 4
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 15
Todo El Tiempo: 1,378
