Saltar al contenido principal
ASUS TUF Gaming FX505DY Back Case Replacement
Qué necesitas
  1. ASUS TUF Gaming FX505DY Back Case Replacement, Back Case: paso 1, imagen 1 de 1
    • Turn off the laptop.
    • Disconnect the charging cable.
    • Failure to disconnect the charging cable and power down the computer could result in personal or property damage.
    • Flip the laptop so the back is facing up.
  2. ASUS TUF Gaming FX505DY Back Case Replacement: paso 2, imagen 1 de 2 ASUS TUF Gaming FX505DY Back Case Replacement: paso 2, imagen 2 de 2
    • Use a Phillips #1 screwdriver to remove the five 6 mm screws that secure the back panel.
    • Use the same screwdriver to remove the six 13 mm screws securing the back panel.
  3. ASUS TUF Gaming FX505DY Back Case Replacement: paso 3, imagen 1 de 2 ASUS TUF Gaming FX505DY Back Case Replacement: paso 3, imagen 2 de 2
    • Insert the plastic opening tool at a corner and pry up along the edges, leaving the back side with the hinges for last.
    • Do not insert the opening tool too far into the laptop to avoid damaging internal components.
  4. ASUS TUF Gaming FX505DY Back Case Replacement: paso 4, imagen 1 de 2 ASUS TUF Gaming FX505DY Back Case Replacement: paso 4, imagen 2 de 2
    • Gently lift up the back panel to release any remaining clips on the side with the hinges and remove the panel.
Conclusión
Una persona más ha completado esta guía.
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 5
Ultimos 30 días: 31
Todo El Tiempo: 971
