Introducción
If your keyboard is stuck or broken to the point where there’s no typing, you may want to consider a replacing the keyboard in your Asus Q302L. Replacing your keyboard with this guide will require you to remove many small components. Pay close attention to what you have removed, and where you removed it from so that it may be replaced in its required position in the new keyboard assembly. This guide will take you through the steps of replacing your keyboard. If your keyboard fails to track input or tracks erroneous input, check out the Asus Q302L Troubleshooting page to verify that your keyboard needs to be replaced.
Qué necesitas
Use a Phillips #0 screw driver to remove all ten 10 mm screws around the back of the laptop.
Use a Phillips #0 screwdriver and remove all five 5 mm screws securing the battery.
Unplug the hard drive from the connector.
Use a Philips #0 screwdriver to remove all four 5mm screws holding the hard drive metal mounting bracket.
Use a Phillips #00 screwdriver to remove all three 4mm screws around the fan.
Using the same screw driver, remove the four 4mm screws from the part of the fan that is above the processor.
Peel back the adhered strip to expose the black and white connections.
Pop the connections off the fixtures.
Carefully disconnect the ribbon connector from the touchpad using an iFixit opening tool.
Slowly peel the grounding strap off of the touchpad.
Use a Phillips #0 screwdriver to remove the three 2 mm screws holding the touchpad.
Remove the three 4 mm screws using a Phillips #0 screwdriver from the right side hinge.
Removal of the right hinge will allow you to remove the display from the keyboard.
