Saltar al contenido principal
ASUS PadFone X Power and Volume Buttons Replacement
Qué necesitas
  1. ASUS PadFone X Power and Volume Buttons Replacement, Power and Volume Buttons: paso 1, imagen 1 de 1
    • Pry off the back cover with the blue plastic opening tool.
    • Removing the cover may require a bit of force.
  2. ASUS PadFone X Power and Volume Buttons Replacement: paso 2, imagen 1 de 1
    • Remove thirteen 3.6mm screws using the T5 Torx Screwdriver.
  3. ASUS PadFone X Power and Volume Buttons Replacement: paso 3, imagen 1 de 1
    • Once the screws are removed, the mid-frame can be lifted off of the phone.
  4. ASUS PadFone X Power and Volume Buttons Replacement: paso 4, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Grasp the button strip with tweezers.
    • Pull the buttons upwards gently. The buttons should remove easily.
  5. ASUS PadFone X Power and Volume Buttons Replacement: paso 5, imagen 1 de 1
    • Use the blue plastic opening tool to disconnect the orange sensor strip.
    • Applying too much force may damage the connector.
  6. ASUS PadFone X Power and Volume Buttons Replacement: paso 6, imagen 1 de 1
    • Grasp the sensor with the tweezers.
    • Pull outwards away from the phone.
    • The sensor is held on by adhesive. You will need to apply some force when removing.
Conclusión
Equipo
IUPUI, Team 2-1, Baechle Spring 2017 Miembro de IUPUI, Team 2-1, Baechle Spring 2017
IUPUI-BAECHLE-S17S2G1
4 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 10
Todo El Tiempo: 266
