Saltar al contenido principal
Partes
No se especificaron partes.
  1. Remove the battery, using release clips. Ensure device has no residual power by attempting boot once battery is removed.
    • Remove the battery, using release clips.
    • Ensure device has no residual power by attempting boot once battery is removed.
    • Remove either 2 (or 4 for a full teardown) 12mm phillips screws, then removing the bottom cover to gain access to the HDD and RAM.
    • Remove HDD and RAM cover
  2. Remove 3 5mm Phillips screws
    • Remove 3 5mm Phillips screws
    • Slide HDD caddy back, remove using the black pull tab.
  3. Remove 4 Phillips screws, 2 per side
    • Remove 4 Phillips screws, 2 per side
    • Remove HDD from caddy.
Conclusión
5 personas más completaron esta guía.
Ryan
Miembro Desde 19/08/15
1,414 Reputación
14 Guías creadas
Un Comentario
What is the spec of the hard drive? SATA 2.5"? Any max capacity or other restrictions on what drops in?
mrgilbe1 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 39
Todo El Tiempo: 5,519
