Saltar al contenido principal
ASUS Chromebook C424MA-DH48F Lower Case Replacement
Qué necesitas
  1. ASUS Chromebook C424MA-DH48F Lower Case Replacement, Lower Case: paso 1, imagen 1 de 2 ASUS Chromebook C424MA-DH48F Lower Case Replacement, Lower Case: paso 1, imagen 2 de 2
    • Use a Phillips #0 screwdriver to remove the eleven 6.9 mm screws that secure the lower case.
    • Make sure all the screws on this side get taken out because there could be a label or warranty sticker covering up a screw that might be missed.
    • Insert an opening pick into the gap between the lower case and chassis.
    • Slide the pick around the entire perimeter of the laptop until the lower case fully releases.
    • Remove the lower case.
Conclusión
Connor
Miembro Desde 03/29/22
12,358 Reputación
64 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
Miembros de 118
19,537 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 16
Todo El Tiempo: 47
