Introducción
The battery for the speaker at the very back of the device. It can be easily burned out or damaged with frequent use.
Before attempting to replace anything, it is recommended that you look at this device’s troubleshooting guide.
If your battery cannot hold charge, has broken wires, or needs to be replaced for some reason, this guide will show you step by step how to replace/remove it. Soldering experience is needed.
You must be careful while replacing the battery. If the battery is having issues, it could have multiple dangerous attributes. Things like battery acid and exploding batteries are not fun to deal with, so approach this task with caution.
Qué necesitas
Use the plastic opening tool to pry off the screen.
Remove the screen from the device.
6 personas más completaron esta guía.
4 comentarios
Nice guide… showed how to get the grill off… Unfortunately, my circuit board is epoxied in place.
Battery tests ok, but unit won’t turn on. Its going into the bag with other non-working electronics unless you have any ideas. The little speakers look very nice…
My Anker works as long as it is plugged in (usb). As soon as the lead is removed, it dies.
Where do I get the new battery in India?
