Saltar al contenido principal
ACER Aspire E1-572-6870 Battery Replacement
Qué necesitas
  1. ACER Aspire E1-572-6870 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Flip your laptop over so the back panel is facing upwards.
    • Locate the lock switch below the battery.
  2. ACER Aspire E1-572-6870 Battery Replacement: paso 2, imagen 1 de 3 ACER Aspire E1-572-6870 Battery Replacement: paso 2, imagen 2 de 3 ACER Aspire E1-572-6870 Battery Replacement: paso 2, imagen 3 de 3
    • Slide the lock switch to the right using your finger or a spudger.
    • At the same time, grasp the battery with your other hand and slide it out of the laptop.
    • Remove the battery.
    • To reinsert or replace the battery, simply line up the tabs on the battery with the laptop and slide it straight back in. There is no need to move the lock switch.
Conclusión
For optimal performance, after completing this guide, calibrate your newly installed battery.
3 personas más completaron esta guía.
Cody Lim
Miembro Desde 01/25/17
1,404 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 9-6, Banghart Winter 2017 Miembro de Cal Poly, Team 9-6, Banghart Winter 2017
CPSU-BANGHART-W17S9G6
3 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 16
Ultimos 30 días: 69
Todo El Tiempo: 5,900
