Introducción
This should provide enough details for those savvy enough to take on the repair project themselves.
10mm bolts are used for the four fender bolts (one on the headlight assembly that may also need to be aligned if planned) and four 12mm bolts are used for the hood hinge (x2 - hood and x2 - frame).
A regular 12mm socket with an extension can be used with either a 1/4" or 3/8" drive noting that you'll have to pull the fender back more for the larger drive if not apparent.
The Video Instructions (3rd video below) I found on Youtube showing a great overview and two videos I made, to document what I noticed wasn't present in as much detail in the 3rd video found, seem to detail enough to take on this chore.
Mainly I made this 1st video to show that the fender didn't have to be pulled out as far, as the 3rd linked video demonstrated, to remove the hinge and that the fender connection behind the side glass window wasn't broken and is only that shape by design from what I observed on all the gen 3 priuses I inspected at the yards. A cloth or piece of leather between the extension is also a good idea so to prevent damage to the fender paint.
I also wanted to show not only a 1/4" or 3/8" drive ratchet with extension (ideally with a magnet at the socket end or be prepared to have a telescoping magnet to remove and insert the bolts) is required. The "1-3/4 in. Impact Rated Magnetic Metric Nut Setters" from Harbor Freight work well and I'd add an "Hercules - Bit - Impact Rated 6 in. Extension Magnetic Bit Holder" or just use the "6 in. Impact Rated Magnetic Metric Nut Setters" or equivalent to reduce the need to pull the fender back as much.
https://www.youtube.com/watch?v=jKwZtXQA...
2009-2015 Toyota Prius Hood Hinge Replacement Additional Info From My Observations
Note that in the 2nd video the Polyurethane I was referring to is the adhesive used to adhere the rubber trim piece that doesn't need to be completely removed. Only peeled back enough to gain access to the 10mm fender bolt that screws into the top of the hinge. The plastic part is removed using a small screwdriver, pry bar or trim removal tool carefully from the front of the piece prying up and towards the side you're working from.
https://www.youtube.com/shorts/LQ1nVn2N2...
2009-2015 Toyota Prius Hood Hinge Replacement Rubber Trim
Qué necesitas
Instrucciones de Vídeo
Una persona más ha completado esta guía.
2 comentarios
As I need to do this to my own 2013 prius hood hinge, I can't seem to find the videos you are referring too. Only the last one where the fender is pulled back completely. DO you have a conclusion or can share access to the videos you trie dot link in this post?
Daniel Nadel - Contestar
I updated with the links. Thanks for asking!
James Finch -
