Introducción
The air filter plays an important role in your engine by keeping dirt, dust, and other debris out of the combustion chamber. Because of that, the air filter needs replaced every 10,000 to 15,000 miles, depending on the driving conditions.
Note: This guide uses a 4.8L V8 engine on a 2007 Silverado to demonstrate the procedure. The air filter size may vary depending on the size of the engine.
Qué necesitas
The hood release handle is located on the driver's side to the left of the emergency brake pedal.
Pull on the hood release handle to pop the hood.
To open the hood, reach into the gap at the front of the truck and feel for the latch. Push it to the left to release it and lift up on the hood.
The airbox cover is fastened down with four Torx T25 screws. Remove each one with a Torx T25 screwdriver.
Grab onto the rubber lip of the old air filter and carefully lift it up and out of the airbox.
Slide in the new air filter and gently set it into the airbox, making sure that it goes all the way in so that you can close the airbox cover completely.
Reinstall the airbox cover and the four Torx screws. You’re all set!
2 personas más completaron esta guía.
