Saltar al contenido principal
2002 Nissan Altima Hubcap Replacement
Qué necesitas
  1. 2002 Nissan Altima Hubcap Replacement, Hubcap: paso 1, imagen 1 de 3 2002 Nissan Altima Hubcap Replacement, Hubcap: paso 1, imagen 2 de 3 2002 Nissan Altima Hubcap Replacement, Hubcap: paso 1, imagen 3 de 3
    • Attach the retention ring to your new hubcap, aligning the divot in the ring with the tire-valve cutout.
    • Be sure to click the ring in each clip around the hubcap.
  2. 2002 Nissan Altima Hubcap Replacement: paso 2, imagen 1 de 1
    • Use a wide tipped removal tool to align the wedge inside the hubcap.
    • You may be able to remove the hubcap with your hands if you grab and pull. Be careful, though, to not injure yourself.
  3. 2002 Nissan Altima Hubcap Replacement: paso 3, imagen 1 de 1
    • Gently push on the solid parts of the hubcap until they pop out of the tire.
  4. 2002 Nissan Altima Hubcap Replacement: paso 4, imagen 1 de 2 2002 Nissan Altima Hubcap Replacement: paso 4, imagen 2 de 2
    • Align the replacement hubcap with the tire valve.
    • There should be a cutout in the hubcap to specifically fit around the tire valve.
  5. 2002 Nissan Altima Hubcap Replacement: paso 5, imagen 1 de 2 2002 Nissan Altima Hubcap Replacement: paso 5, imagen 2 de 2
    • Keeping alignment, hold the center of the hubcap and forcefully push in all the sides of the inner ring until it secures in place.
  6. 2002 Nissan Altima Hubcap Replacement: paso 6, imagen 1 de 1
    • Repeat steps 1-5 for other three tires.
Linea de Meta
Bre Sanders
Miembro Desde 04/26/24
133 Reputación
1 Guía escrita
Equipo
UC Davis, Team 2-6, Whithaus Spring 2024 Miembro de UC Davis, Team 2-6, Whithaus Spring 2024
UCD-WHITHAUS-S24S2G6
2 Miembros
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 80
