Saltar al contenido principal
1992-1999 BMW 3 Series Oil Replacement
Qué necesitas
  1. 1992-1999 BMW 3 Series Oil Replacement, Oil: paso 1, imagen 1 de 2 1992-1999 BMW 3 Series Oil Replacement, Oil: paso 1, imagen 2 de 2
    • Open the hood of the car by first pulling the black lever located in the drivers side footwell.
    • Lift upward on the latch located underneath the hood to release the hood.
  2. 1992-1999 BMW 3 Series Oil Replacement: paso 2, imagen 1 de 2 1992-1999 BMW 3 Series Oil Replacement: paso 2, imagen 2 de 2
    • Jack up the car using the jack points located underneath the sides of the car.
    • Tip: it is advised to use Jackstands to support the car in case of jack failure.
    • Tip 2: It may only be necessary to lift one corner of the car in order to change the oil. The right front jack point seems to be the best for this.
  3. 1992-1999 BMW 3 Series Oil Replacement: paso 3, imagen 1 de 3 1992-1999 BMW 3 Series Oil Replacement: paso 3, imagen 2 de 3 1992-1999 BMW 3 Series Oil Replacement: paso 3, imagen 3 de 3
    • Place the oil pan underneath the plug
    • Using a 17mm socket, remove the drain plug.
    • Allow the oil to fully drain into the oil pan.
    • Reinstall the drain plug after the the oil stops dripping from the drain hole.
  4. 1992-1999 BMW 3 Series Oil Replacement: paso 4, imagen 1 de 3 1992-1999 BMW 3 Series Oil Replacement: paso 4, imagen 2 de 3 1992-1999 BMW 3 Series Oil Replacement: paso 4, imagen 3 de 3
    • Remove the Oil Filter Housing bolt using a 13mm socket. Lift upwards on the oil filter housing cap to remove it.
    • Lift the old oil filter straight up to remove it. Place a towel underneath it as you lift to catch any dripping oil.
    • While the oil filter is out, inspect the gaskets on the oil filter housing cap and bolt. Replace if necessary.
    • Install the new oil filter and reinstall the oil filter housing.
  5. 1992-1999 BMW 3 Series Oil Replacement: paso 5, imagen 1 de 3 1992-1999 BMW 3 Series Oil Replacement: paso 5, imagen 2 de 3 1992-1999 BMW 3 Series Oil Replacement: paso 5, imagen 3 de 3
    • Remove the oil filler cap and slowly pour seven quarts of oil into the engine.
    • Pull the Dipstick out and inspect the oil level. The oil level should be between the two marked lines.
Conclusión
Place the oil cap back on, close the hood, and lower the car. You have now successfully changed the oil on your BMW E36.
2 personas más completaron esta guía.
Geoff Wacker
Miembro Desde 09/30/13
90,072 Reputación
89 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 7
Ultimos 7 días: 39
Ultimos 30 días: 206
Todo El Tiempo: 5,271
