Preguntas populares del foro
Haz una preguntaNo hay preguntas. ¡Sé el primero en hacer una pregunta!
General
The Elli Charger Standard serves as the base model within the Elli Charger lineup. It provides a convenient home charging solution for electric vehicles, delivering up to 11 kW of charging power. Equipped with an integrated charging cable, it's compatible with Type 2 connector-equipped EVs. This straightforward option offers a user-friendly way to charge your electric vehicle at home, devoid of the advanced smart features found in the higher-tier Elli Charger models.
Technical Specification
Product Configuration
Charging Mode | Mode 3 (IEC 61851) |
Access Control | - |
Internet- / Network Communication | - |
Communication Protocols | - |
Metering | - |
Electrical Properties
1 Phase | 3 Phase | |
Rated Voltage (± 10 %) | 1x 230 V | 400 V (3x 230 V) |
Rated Frequency | 50 Hz | |
Rated Current | 1x 32 A | 3x 16 A |
Max. Charging Capacity (depending on individual configuration) | 7,4 kW | 11 kW |
Charging Plug | AC – Type 2 | |
Charging Cable Length | 4,5 m or 7,5 m | |
Installation Wiring Cross Section | 1 – 10 mm2 | 1 – 6 mm2 |
Internal Earth Leakage Sensor | IΔn DC ≥ 6 mA (IEC 61851) | |
Additionally needed Upstream Protection | - Residual Current Detection minimum Type A (30 mA AC) - Circuit Breaker 32 A (1 Phase) or 16 A (3 Phase) |
Physical Properties
Dimensions [W x H x D] (in mm) | 297 x 406 x 116 |
Status Indication | LED based HMI |
Enclosure Ratings | IK 10 (IEC 62262) IP 54 (IEC 60529) |
Weight (depending on variant and charging cable length) | 5,6 kg … 7 kg |
Operating Temperature | -30 °C … +50 °C |
Max. Humidity | 95 % (non-condensing) |
Max. Altitude | 4000 m a.m.s.l. |
Mounting Method | On Wall |
Dynamic Load Management | via AC Current Sensors (optional additional material needed) |
