Preguntas populares del foro
Haz una preguntaNo hay preguntas. ¡Sé el primero en hacer una pregunta!
General
The Elli Charger Pro, tailored especially for users with company cars, represents the highest end option in the Elli Charger range. It provides a convenient home charging solution for electric vehicles, delivering up to 11 kW of charging power. Equipped with an integrated charging cable, it's compatible with Type 2 connector-equipped EVs. What sets it apart from the base model is its advanced connectivity features, including LAN, Wi-Fi, and LTE/4G support. These features enable remote monitoring, app control, RFID access protection, and support for EEBUS communication, facilitating intelligent energy management for your home. Additionally, it incorporates a MID-certified electricity meter, making it suitable for employers to reimburse work-related charging costs.
Technical Specification
Product Configuration
Charging Mode | Mode 3 (IEC 61851) |
Access Control | RFID (IEC 14443 A/B, ISO 15693) |
Internet- / Network Communication | WiFi (2,4/5 GHz - 802.11 b,g,n) Ethernet (via RJ45) 4G/LTE |
Communication Protocols | OCPP 2.0J EEBus |
Metering | MID Meter |
Electrical Properties
1 Phase | 3 Phase | |
Rated Voltage (± 10 %) | 1x 230 V | 400 V (3x 230 V) |
Rated Frequency | 50 Hz | |
Rated Current | 1x 32 A | 3x 16 A |
Max. Charging Capacity (depending on individual configuration) | 7,4 kW | 11 kW |
Charging Plug | AC – Type 2 | |
Charging Cable Length | 4,5 m or 7,5 m | |
Installation Wiring Cross Section | 1 – 10 mm2 | 1 – 6 mm2 |
Internal Earth Leakage Sensor | IΔn DC ≥ 6 mA (IEC 61851) | |
Additionally needed Upstream Protection | - Residual Current Detection minimum Type A (30 mA AC) - Circuit Breaker 32 A (1 Phase) or 16 A (3 Phase) |
Physical Properties
Dimensions [W x H x D] (in mm) | 297 x 406 x 116 |
Status Indication | LED based HMI |
Enclosure Ratings | IK 10 (IEC 62262) IP 54 (IEC 60529) |
Weight (depending on variant and charging cable length) | 5,6 kg … 7 kg |
Operating Temperature | -30 °C … +50 °C |
Max. Humidity | 95 % (non-condensing) |
Max. Altitude | 4000 m a.m.s.l. |
Mounting Method | On Wall |
Dynamic Load Management | via AC Current Sensors (optional additional material needed) |
