Saltar al contenido principal
Todo lo que puedas necesitar para reparar tu iPhone tú mismo Desde la línea más reciente de iPhone 15, hasta el iPhone 2G original lanzado en 2007, iFixit tiene guías de reparación gratuitas e información de desmontaje para cada iPhone, así como las mejores piezas de repuesto, herramientas y consejos de la galaxia.
Preguntas 36501 Ver todo
I dropped my iPhone and now it has a white screen
I droppe my iphone today and it fell to the floor. When I saw it, it had a white screen. Everything works yet. I tried to turn it off, and I could do it because ALL the buttons still working, but just the screen is white. Also, I'm receiving text messages (because it rangs when I receive one). I tried to restore it with the power and home button but anything happens. Should I change my LCD screen?
PLEASE, I WAIT FOR YOUR ANSWER ASAP!
And sorry for my english, is not my first language.
Regards
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 5
Agregar un comentario
6 Respuestas
Respuesta Más Útil
It sounds like you may have just knocked a cable loose when you dropped it. The LCD screen doesn't sound necessarily damaged and it sounds like the rest of the phone remains functional.
iFixit has a Guide available for a possible fix here:
iPhone 3G Display Replacement
If I'm correct, what you're looking for is the black ribbon cable in step 4 labeled "1".
It's connected to a plug style connector, the block at the end of the cable is the plug which is simply pushed into a socket on the circuit board.
Ensure that this is connected and reconnect it if it is not and see if that solves the problem.
There is no locking mechanism or anything so it should be too hard to fix.
Fue útil esta respuesta?
Puntuación 3
2 comentarios:
I have already done it. the plug number 1 was disconnected. But, anything happened.. do you think is the screen?
- de
It is also important to ensure that the ribbon cable is seated correctly. The fall may have simply jostled it out of place. I'd unplug and replug it in to make sure its securely connected. If you've done this and the screen remains white, that could mean that the hardware itself was damaged in the fall. And replacing the screen could address the issue if that was indeed what was damaged.
- de
i think you dont need to change your LCD its your screen i think you have to change your screen . my friend also has that the same problem .
Puntuación 0
1 comentario:
yep that is what we had to do
- de
just take it to batteries plus, my mom had the same problem on her iphone5 c. :)
Puntuación 0
I dropped my iphone 4S and the screen turned white. But the phone itself seemed to be functioning. I stood the phone up on its end at an angle of about 20 degrees on a table and let it fall backwards, with the screen facing upwards, the small impact made the screen come back to normal. Clearly there is a part loose in the phone but i haven't taken it in for repair yet. That was about six months ago.
Puntuación 0
1 comentario:
I have the same problem
- de
HELP!!! I dropped my iPhone and its black with white lines. I'ts not responding it still buzzes when i charge it but nothing is happening! its not like white lines on your iphone when its active! I NEED A CHEAP EASY WAY PLEASE!!!!!!!!!!!!!!!!!!!!!
Puntuación 0
i have this exact same problem too. Apparently its £80 to repair but i'd advise you to get a new phone as they may not be able to repair it
Puntuación 0
Añadir tu respuesta
Antonella estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 11
Ultimos 7 días: 91
Ultimos 30 días: 398
Todo El Tiempo: 29,858
