Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Modelo A1181: procesador Core 2 Duo de 1.83, 2, 2.1, 2.13, 2.16, 2.2 o 2.4 GHz
Changing cooling paste on MacBook Core 2 Duo
I have a question about changing/refill the cooling paste on a macbook core 2 duo. The CPU in my macbook is often very warm when I'm running small processes. I'm thinking about refill the cooling paste, so does anyone know how to refill it?
Es esta una buena pregunta?
Puntuación -1
Agregar un comentario
1 Respuesta
Solución Elegida
Yes it's a good idea to replace the thermal paste when you have a heat issue with your macbook or for heat problem prevention specially if your machine is aging. Once the heatsink and the fan are removed from the mac you should also consider a fan clean up with compressed air. You can also easily open the fan, dust it off and clean the blades with isopropyl alcohol.
For the thermal paste replacement please click these links:
Reemplazo del disipador de calor del MacBook Core 2 Duo
Cómo aplicar pasta térmica
Imagen de MacBook Core 2 Duo Disipador de calor
Guía
Dificultad:
Difícil
45 minutes - 2 hours
Imagen de Electronics Skills
Guía
Dificultad:
Moderado
5 - 20 minutes
Fue útil esta respuesta?
Puntuación 6
Añadir tu respuesta
Morten Kvisvik Larsen estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 16
Todo El Tiempo: 11,814
