The Nintendo DS is Nintendo's seventh generation handheld game console.
Preguntas 43 Ver todo
Direction button is unresponsive?
Does the circuit board have to be replaced if the direction button is not working or can it be fixed?. It is only when it is pressed upwards all other directions seem to be working ok. The case has not been changed its the original.
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Agregar un comentario
1 Respuesta
Solución Elegida
The rubber underneath the directional button needs replaced or the motherboard needs cleaned where the rubber piece makes contact. You will need a triwing screwdriver to take it apart. Be careful with the video cables. You will need to remove the motherboard to repair this. Instructions for that are here.
Fue útil esta respuesta?
Calificación 2
Añadir tu respuesta
fernanda estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 2
Todo El Tiempo: 1,740
