Saltar al contenido principal
Modelo A1297 Unibody: principios de 2009, mediados de 2009, mediados de 2010, principios de 2011 y finales de 2011
Preguntas 544 Ver todo
Any way to patch dents/marks in unibody
At this point, by the place the laptop's display is showing it's age because it has chips of aluminum that look chipped
Is there any way to patch this or does the unibody have to be replaced outright
BTW, there is a slight dent i don't care about too much, you can't see it unless you look in light on a angle
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
1 Respuesta
Solución Elegida
If you've got the missing chunks, super glue does alright on metals. The dent MAY be able to be pulled via a suction cup or some similar utility...if you need to fill the dents you may be able to find colored car body filler, though I'm personally a fan of Bondo and paint :D. (Not that I've used it for this particular application mind you...)
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
Nick estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 8
Todo El Tiempo: 2,236
