Saltar al contenido principal
Lanzado en Septiembre 16, 2016. Modelos 1660, 1778. Disponible en GSM o CDMA / 32, 128, o 256 GB / Oro Rosa, Oro, Plata, Negro Mate y Negro Brillante.
Preguntas 2264 Ver todo
LCD malfunctioning with a fully working touch screen glass screen
I recently dropped my iPhone 7 on the floor with the back facing the floor. When I lifted it up its shape seemed to be fully intact , it`s LCD was malfunctioning ( It seems as if the upper part of the screen is working but reflecting the lower part of the screen at the same time; there is a crack beneath the glass screen and not on the screen that can be seen when the phone gets lit up) and its glass screen was fully intact. I was able to use all the function on the phone including touch screen, camera and listening to music .
After a few inspections on my phone, I realised it is very slightly bent ( almost impossible to see). The phone`s LCD sometimes works ( the image can be perfectly seen but there are transparent lines going throw it and the crack still stays) and soemtimes doesn`t ( the upper corner of the screen has coloured lines going throw it and the weird reflection can be seen again).
What happened? How much does it cost to rapair? Shpoul I repair the phone?
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Sounds like you need a screen replacement. Look over the guide and see if it’s something you think you can do yourself, otherwise you can take it to a shop and they will fix it up for you.
LCD iPhone 7 y reemplazo de digitalizador
Fue útil esta respuesta?
Puntuación 1
2 comentarios:
how much would it cost for someone professional to replace it
- de
Alexander,
My store charges $99 USD to replace the screen on an iPhone 7, but it is going to vary greatly depending on where you are and the stores in your area.
- de
Añadir tu respuesta
Alexander Alexandrov estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 62
