Saltar al contenido principal
Información y guías de reparación para el iPhone 6 que salió a la venta el 19 de septiembre de 2014. Números de modelo: A1549, A1586 y A1589
Preguntas 4994 Ver todo
Inaccurate GPS despite new flexi cable
Hi all,
I have an issue with my iphone 6. The GPS was playing so I've replaced the flexi as well as the wifi antenna(second time in 6 months).
However, despite new flexi cable, it's still very inaccurate. Things I have tried so far:
Hard reset
reinstalled google maps
reset network settings
reset gps settings
Nothing seems to work. I'm wondering if I have to refit the antenna or something. How do i know if if its fitted correctly or is there anything that I should looking for when taking it apart?
Any advise would be much appreciated
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Solución Elegida
Your problem could be logic board based. If you have already changed antennas a few times, I would suggest that the problem is not antenna based as they should not fail and certainly shouldn't fail more than once. Take a look at this link to see pictures of where the GPS functions are located and closely inspect your logic board to make sure nothing is obviously wrong.
Fue útil esta respuesta?
Puntuación 1
3 comentarios:
Thanks for the answer. I will take a look tomorrow at the board. Will report back
- de
If you found this answer helpful, please select "Was this answer helpful? - YES" and/or if this answer solved your problem, please “Choose as Solution”. This allows people in the future to understand which answers helped solve the problem and adds value to the site. - Thanks
- de
Of course I will. No problem
- de
Añadir tu respuesta
TomTom estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 4
Todo El Tiempo: 131
