magsafe charger is overheating and sometimes laptop does not charge.
The charging symbol sometimes has a white background with the electricity signal but it often does not charge the macbook.
Es esta una buena pregunta?
At this point you're going to need to pop the logic board out and do a detailed inspection on both sides. Follow this IFIXIT guide: Pro 13" Retina Display Mid 2014 Logic Board Replacement. I'm suspecting you have some corrosion or a failing chip on the logic board.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 513
Did you have a liquid spill or sit the system down on a wet surface at some point?
- de Dan
