Saltar al contenido principal
Modelo A1418 / Finales de 2013 / 2.7 y 2.9 GHz Procesador Core i5 o 3.1 GHz Core i7
Preguntas 254 Ver todo
LCD screen blank - but external monitor is working
I have spent some time on your site, and found similar problems I experience. My iMac screen is black to the naked eye, when plugging in a external monitor it works, and shining a flashligh on the screen reveals that my screen is still working, so my guess is the LED driver portion of the main board is faulty, is there anyway I can fix this?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Respuesta Más Útil
It sounds like the backlight went out. I usually recommend screen replacement unless you have incredible micro soldering skills. You may have to purchase a damaged unit and use the screen off of it or purchase a new screen. Looks like a new screen is under $200 HERE
And HERE is how to replace the screen
Fue útil esta respuesta?
Puntuación 1
2 comentarios:
Yes, in my experience it is the backlight.
- de
"unless you have incredible micro soldering skills" - is there a component / fuse I can replace on the main board to make this work, from what I can see on other sources and this one, it is mainly a fuse on the main board that needs replacement, I will be more than happy to try and fix it , my soldering skills are not too bad :)
- de
Añadir tu respuesta
Arno Janse van Rensburg estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 148
