No start or crank
Battery is good checked all the cables and fuses are good still nothing
Es esta una buena pregunta?
First, turn on headlamps. If they're bright, and don't dim when the key is turned, the battery is o.k. listen for a click. if you hear any click, it's probably the starter. No click - try turning the key with the shifter in "N" Nothing - back to Park. At this point, it could be anything; ignition switch, neutral safety switch, open wiring, etc. If you want to pursue it yourself, you have to get a wiring diagram and test point to point. It can't be diagnosed on line.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 31
Todo El Tiempo: 3,028
