Saltar al contenido principal
IPad 2 GSM con 16, 32 o 64 GB de almacenamiento y un procesador Dual Core A5. Número de modelo A1396. La reparación es complicada y requiere calor y palanca.
Preguntas 152 Ver todo
Digitizer won’t respond to touch after being replaced
I repaired an iPad 2 by replacing a digitizer before peeling back the adhesive strips I tested it. The new digitizer it will not respond to touch. I made sure all of my ribbon cables were connected properly and it still won’t respond to touch.
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Chances are the digitiser is faulty if you tried testing it before installation. As you said you have fully plugged in the digitizer ribbon cable.
Fue útil esta respuesta?
Puntuación 2
1 comentario:
Thank you for your advice. I have solved my problem. I really appreciate your advice in solving my problem.
- de
Añadir tu respuesta
Pbearbear estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 6
Ultimos 30 días: 8
Todo El Tiempo: 56
