Repair and disassembly guides for microwave ovens.
Preguntas 415 Ver todo
Why is my microwave immediately shutting down?
Panasonic Over The Range Microwave Oven Model NN-P295 shuts down immediately no matter what program is selected. It started doing this after the exhaust door at the top was pushed closed while it was running. I will try to add pictures showing the door st the top of the microwave.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Agregar un comentario
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
1 Respuesta
There is a switch located behind that vent. There is a possibility that by forcing it shut you through the shaft that opens and closes the vent out of allignment with that switch. Or the motor to the vent has been damaged or the shaft it self broke. Can you here any kind of motor attempting to open the vent. Does the vent still open?
Fue útil esta respuesta?
Calificación 0
Comentarios:
Also did it continue to run after the vent was forced close?
por
The vent still operates so it looks like all is OK there. The vent closes right away .
por
Añadir tu respuesta
Bruce Herbert Maynard estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 63
