Saltar al contenido principal
Repair guides and support for motorcycles manufactured by Harley-Davidson.
Preguntas 77 Ver todo
rear brake engaging after riding for aprox. 25 minutes
My rear brake get extremely hot and self engages braking the bike after riding aprox. 25 minutes . I have bled the brakes several times with about 2 pints of dot 5 to remove any air and this continues to happen . 1999 softail . Suggestion please !
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Solución Elegida
@hel69 check your caliper to make sure it is not seized and continues to apply the brakes during normal driving.
Fue útil esta respuesta?
Puntuación 2
3 comentarios:
Thank you i will continue using the brake I did let some pressure off after riding when it was binding and hot. I think it helped.
- de
I have bleed the rear brake many times and still it closes when hot .I'm thinking maybe the rubber hose is collapsing when hot . ill continue to work at it . thanks anyway
- de
@hel69 that sounds very reasonable. Let us know what ended up working for you.
- de
Añadir tu respuesta
Harry Helmly estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 6
Todo El Tiempo: 271
