Saltar al contenido principal
El iPhone 5s de Apple fue anunciado el 10 de Septiembre, 2013. La reparación de este dispositivo es similar a los modelos anteriores y requiere destornilladores y herramientas de palanca. Disponible como GSM o CDMA /16, 32, o 64 GB / Plata, Oro, y Gris Espacial.
Preguntas 3530 Ver todo
Pressure point on screen after replacement
My phone fell down and screen got cracked, I went up to an ifix store and changed the screen. When I got it back, it had a pressure point - when I asked the guy he said it was there before when you dropped it. But I am very sure it wasn't there before. He mentioned it might have happened when I dropped it.
I checked online forums and it said it usually happens when you replace it and don't use adhesive or press the screen? Is this true? I still have a 30-day warranty. I am planning to go back to him and tell him all these stuff.
Also, would the pressure point go away after replacing the screen again?
Please Advise.
Update with Picture (10/21/2017)
Es esta una buena pregunta?
Puntuación 1
2 comentarios
Hi Rohit,
Can you post a photo of this pressure point?
- de
Mine is this way as well. There are also multiple light blue lines or spots on the screen.
- de
Agregar un comentario
1 Respuesta
Solución Elegida
@rohitsuresh26 sound s a bit like a phony story to me. "it was there before when you dropped it." would not show up on a new display. personally I'd take it back and either have them fix it properly, or I'd replace it myself. iFixit has awesome guides like this Sustitución de la pantalla del iPhone 5S for the task and the part is available right here iPhone 5s Screen Probably a bit more than the "ifix store" but at least you get a known high quality product with a warranty that will be hard to match by anyone.
If you really are not sure and want to verify this, just post a couple of good images of what your screen displays. Use this guide for that it will allow us to see what you see.
Imagen de iPhone 5s Screen
Producto
iPhone 5s Screen
$34.99
Imagen de iFixit
Guía
Agregar imágenes a una pregunta existente
Dificultad:
Muy fácil
2 - 5 minutes
Imagen de iPhone 5s Pantalla
Guía
Dificultad:
Moderado
30 minutes - 1 hour
Fue útil esta respuesta?
Puntuación 2
3 comentarios:
@oldturkey03 Thank you for your valuable reply. I have updated my question with an image. If you see the area near the top right corner where the battery percentage is shown you can see the pressure point.
I'm planning to take it back to the store since I already spent $50 there ( Sadly I know it was pricey :( ). I was just curious to why it actually happened? and would telling them to replace it again solve the problem? Like, would it remove the pressure point? I hope so!
Please Advise.
Regards,
Rohit
- de
@rohitsuresh26 yes a new display should fix this, for as long as the installation has been done right.
- de
Añadir tu respuesta
Rohit Suresh estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 2,367
