Saltar al contenido principal
The 2009-2014 Ford F-150 was introduced for the 2009 model year as an update of the Ford full-size truck platform.
Preguntas 73 Ver todo
trailer running lights not working at plug on truck
which fuse do i check?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
1 comentario
# F 150 which fuse should I check when my trailer light not working
- de
Agregar un comentario
3 Respuestas
Respuesta Más Útil
Daleo Kelso this will only work if your truck has the trailer towing package. If it has been wired aftermarket, you'll have to dig a bit for it. For the truck equipped with the package:
Fuse F31 will be for the parking lights on the trailer connector and Fuse F58 is for the trailer connector backup lights.
Fue útil esta respuesta?
Puntuación 2
Check #67 under the hood behind radiator. There is a fuse box there. I had same problem. It's a 20 amp blue 1cmx1cm square style with clear window at top. A simple continuity test will tell if it's bad.
Puntuación 1
1 comentario:
trailer is working good now.
- de
Look under the lid of the fuse box. Should tell you.
Puntuación 0
Añadir tu respuesta
Dale Kelso estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 17
Ultimos 7 días: 117
Ultimos 30 días: 433
Todo El Tiempo: 38,351
