Saltar al contenido principal
Encuentra soluciones a tus preguntas sobre reparación de ordenadores.
Preguntas 21327 Ver todo
Replaced Dead drive with SSD
hey guys!
about a month ago, i went to boot my PC. it was booting to a black screen, then after 10 minutes or so, it went to the recovery mode, in which i ran the CMD prompt, and found the registry hive had been completely wiped.
I installed windows, which ran for about a week, before it started booting to "Boot Mngr missing" After a drive pull, i found that the system drive was failing. after this point, running my windows disk allowed me to boot to install on a drive, however, i didnt want to format my slave drives.
so i ordered a new 250GB Samsung SSD to install.
i installed the device, and now i dont get any image on my PC. not even a bios screen.
What could have caused this, and how can i fix it?
Es esta una buena pregunta?
Puntuación 1
3 comentarios
You may need to preform a static discharge as you may have created a static build up when you were working on the machine . To do this unplug the machine so it has no possible power source and hold the power button down for 60 seconds . Then plug in the PC and reboot . Try this and if this doesn't work we will move on to checking memory and apu
- de
i have preformed the discharge. no change in function.
I also tried booting with no RAM, which should give me a message on screen. still no video output to see the message.
- de
the questions been pushed too far back.
bump
- de
Agregar un comentario
1 Respuesta
Solución Elegida
Have you checked all your cables and video connections ? What motherboard is in the PC ? Try unplugging the ssd and booting to the bios . If this cant be done then there's another issue. Let use know what happens and well go from there.
Fue útil esta respuesta?
Puntuación 2
5 comentarios:
Yes
gigabyte Gaming 5
device acts as if booting, but monitor receives no output
- de
- de
66.6K...the number of the BEAST!
- de
@refectio nasty I need to get past this
- de
- de
Añadir tu respuesta
Scott estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 64
