Replaced Dead drive with SSD
hey guys!
about a month ago, i went to boot my PC. it was booting to a black screen, then after 10 minutes or so, it went to the recovery mode, in which i ran the CMD prompt, and found the registry hive had been completely wiped.
I installed windows, which ran for about a week, before it started booting to "Boot Mngr missing" After a drive pull, i found that the system drive was failing. after this point, running my windows disk allowed me to boot to install on a drive, however, i didnt want to format my slave drives.
so i ordered a new 250GB Samsung SSD to install.
i installed the device, and now i dont get any image on my PC. not even a bios screen.
What could have caused this, and how can i fix it?
Es esta una buena pregunta?
3 comentarios
You may need to preform a static discharge as you may have created a static build up when you were working on the machine . To do this unplug the machine so it has no possible power source and hold the power button down for 60 seconds . Then plug in the PC and reboot . Try this and if this doesn't work we will move on to checking memory and apu
- de Jimfixer
i have preformed the discharge. no change in function.
I also tried booting with no RAM, which should give me a message on screen. still no video output to see the message.
- de Scott
the questions been pushed too far back.
bump
- de Scott
