Spins when not on, does not spin when on Sprayed WD 40 on accident
Ok so i was trying to get the motor out of the shell and i ended up spraying wd 40 to loosen it up only to realize the motor doesnt spin anymore and makes a very loud humming sounds and is very hard to spin but it spins freely when it is off (it use to work just fine)
EDIT: the red tape is for the wiring not to conduct to cause a short circuit
Update (09/24/2017)
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Agregar un comentario
1 Respuesta
Respuesta Más Útil
sethlikes22 sounds like a motor start capacitor issue or a winding issue. You would need to give us a complete model number and post a few images of your fan with your question so we can see what you see. Use this guide Adding images to an existing question for that.
Update (09/23/2017)
Loving it already! That looks awesome and very rustic. Thanks for the images. Just give us more details about what you have going on within the area of the red tape.
Maybe a different angle will show us more. Hope you own a multimeter so that you can do some resistance testing. Looks like you are having some issues with your field pole windings. This would also explain why your motor won't turn
Fue útil esta respuesta?
Calificación 1
Comentarios:
Ok added the pictures i forgot too
por
i also dont know the model number nor do i know the fan model number i cant find it anywere
por
Updated post
por
do you think maybe you could help i dont have a multimeter or anything to test it just some motor oil and electrical tape and wire nuts
por
sethlikes22 sorry but you will need a multimeter to check this. Where are you located? What other tools can you get your hands on? Post some pictures of the area I marked. Lets see what you have covered up.
por
Mostrar 32 comentarios más
Añadir tu respuesta
sethlikes22 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 93
