Released on September 19, 2014, this 4.7" screen iPhone is the smaller version of the iPhone 6 Plus.
Preguntas 4100 Ver todo
iPhone 6 with no image after screen replacement
I've been fixing iPhones for a while now with no problem. This time that I fixed it for a friend i replaced it with no problem it turned on and everything and about a week later the phone just went black but it is recognized when I connect it to iTunes. Could it be the logic board that was damaged? The phone has never been wet either.
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Agregar un comentario
4 Respuestas
Solución Elegida
Have you checked the connector on the logic board? Check whether it is in good condition and clean it with Alcohol cleaning fluid to have a try.
Fue útil esta respuesta?
Calificación 2
Comentarios:
I will try this thank you
por
After trying this multiple times it finally worked
por
Can you verify if it's no image or no backlight? Try shining a light on the screen and see if you can see anything. If so, it could be a problem with your backlight circuit.
Calificación 1
Comentarios:
There was light at first looked kind of purple but then just went out
por
This happend to me but on a different phone. The screen is broken talk with your seller
Calificación 0
Comentarios:
I thought it might be that too but i tried 3 different screens and one original that just had a crack
por
how you fixed your problem? please tell me, I have same problem
Calificación 0
Añadir tu respuesta
Alex estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 4
Últimos 30 Días: 20
Todo El Tiempo: 182
