How to reset security system
I can not turn the security system off. The battery is dead and as soon as I try to use jumper cables, the alarm goes off
Es esta una buena pregunta?
Lester Moorman, If possible charge your battery 12.2V+ or change it, as this could continue happening. Try alarm rest procedure below.
Insert the ignition key in the Accord's driver-side door lock.
Turn the key to the unlock position.
Turn the key to the lock position.
Turn the key back to the unlock position. The alarm should now be disabled.
Start your Honda Accord's engine and allow the vehicle to run for at least 10 minutes. This will allow the Accord to reset the alarm. When you're done, you can shut off the Accord and arm the system as usual.
The links may also help. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Fue útil esta respuesta?
Tried it. It does not work.
I had the same problem on a 99 accord, the instructions did not work for me either.
So I left the keys in the ignition and accidentally locked myself out. After opening the passenger side door with a hanger wire, the alarm would go off everytime, even after opening the car with the key. I followed the instructions on how to reset the alarm but it would still go off. What i found out is that since i opened the door with the hanger, i had to reset the alarm inserting the key on that same side (passenger side). Anyways, hopefully this helps somebody else.
Had the same problem with my '01 Accord Coupe. Went to jumpstart it and, as soon as the circuit was closed, the horn started its cacophony. As well, the lights began switching on and off.
I quickly pulled that last connection away and thought, "S*!t, now what?" "Anti-theft system is what." I pulled the horn relay - which is located in the fuse box under the hood. I jumpstarted it and, soon after, found that the battery needed to be replaced.
Battery replaced, I still had the issue of the flashing lights (and no horn). The lights will stay on without flashing by simply turning on the lights.
I also noted that the cruise control was disabled. However, the green LED on the cruise dash button indicated that the system was functional. I hypothesized that the steering wheel buttons for the cruise control had been disabled when the horn relay was removed.
I found the answer posted here and followed the steps. It worked. I replaced the horn relay. The cruise control is functional again also. Thanks!
Thank you! Worked like a charm and saved me lots of money... And I didn't have to disconnect the wiring harness like I thought I did!
I had this same problem with my 2001 Honda Accord. I followed the steps as stated and it worked right away. This process was a quick fix. Thanks again!!!
once the alarm goes off, stop it using the alarm button on your transmitter.
What if you don't have the transmitter? I'm trying to figure out how to do it manually.
Mine is 2000 Honda Accord. Installed new battery and alarm goes off. I quickly use key fob and hit unlock button, this will stop alarm. Joe
Well this dumb thing sorry didn’t know i needed a account to help you with your problem!! But like i said there sometimes this hast to do with the hood latch there is actually a electric plastic plug if you would under your hood if you lift your hood having the key fob in your hand you can lock your doors open your hood so much as air can set your alarm off but there is a little spring with a hook on it sometimes you can bend that its a tight fit but with a flat head screwdriver towards the passengers side of the vehicle just in the least bit but make sure it is indeed bent that may fix your issuse the connector i’m talking about should just pull right up but you do have a notched clip so make sure you pull the notch back first before pulling up but hopefully that solves your problem!! Or try a new battery in the fob or may need a whole new fob. Honestly their is a laundry list of things little minor things it is nothing big. Except very annoying. Hope this helps tried to post it above but it deleted it.
Thanks, I've torn that car apart and put back together tryn to solve it so prob just gonna leave unlocked since dont keep $@$* in car, and if they steal it then I got full coverage hahahha...just tired of whole situation hope to save enough to get another soon
Hi I have a 2001 with the same problem I tried resetting it by unlock lock unlock on the driver door didn’t work I tried the same on the passenger door and wa la my problem was fixed no more aggravating alarm everytime I reconnect the battery
1999 Acura - same issue with changing the battery. The alarm sounded and I couldn't reconnect the battery. I tried all posted remedies including the one above and watched all videos with no success. I finally disabled the horn by removing the Horn Relay (fuse) from the under hood fuse box. With that removed, I was able to connect the battery. The horn didn't sound but the headlights were flashing. I started the car, stopped the car. I used the key to "unlock / lock / unlock" the car per the alarm reset protocol. I started the car and everything works fine now. Of course I had to reset the radio via the code that is inside of the glove box.
I locked the doors to my friends Honda civic the key won’t open the door from the outside. The lock smith unlocked it but now the lights are blinking off and on what do i do
I lock my door to my honda accord 2001 and the key won't let me opened the door from the outside and that the only way of me getting in my car now that I unlock it by pushing the window down my horn going off my lights are blinking off and on what can I do to stop it from doing that
Ultimas 24 horas: 25
Ultimos 7 días: 228
Ultimos 30 días: 979
Todo El Tiempo: 167,237
12 comentarios
why does the sound of the car fob comes while i am driving and turn on the security alarm of my honda accord 2001. security alarm light turns on and off after few minutes. problem is all the time it turns on, car fob sound comes even in the middle of the traffic. how do i disable the alarm or fix this issue
- de prabhath
How do you reset the fuel and spark to the engine
- de Felicia Lipps
How can i my it work
- de Patrick Sullivan
I don't get it I'm not stupid when it comes to cars I had the alarm working and I don't know what happened but it shut off!! Now I'm trying to figure out how to enable the alarm not disable it. My security light is not on the door but it is on the radio but usted to be able to hit the unlock button twice and it would engage now it's not for some reason any answers to this question would be extremely helpful thanks!!
- de Rich Wheeler
My alarm will not go off when I put my key in the door nor when I put it in the ignition, what should I do?? When unplugging the battery it goes off but once I put my key in the door it goes back off!!
- de ericashanae_2005
Mostrar 7 comentarios más
