Saltar al contenido principal
Modelo A1278 / 2.26 o 2.53 GHz Procesador Core 2 Duo EMC 2326 de mediados de 2009
Preguntas 745 Ver todo
Why does my MacBook Pro shutdown when the battery is between 50-30%?
My MacBook Pro 13" 2009 Unibody shuts down randomly. I purchased it from a friend. I noticed the battery needed to be serviced and the body below the keyboard would get hot, so I got a new one installed at a local Mac repair shop. New battery is great, low cycle count. Heat issue was better. It even charges up to 100% percent no problem. But when it is off the charger and goes down to say below 50% it will automatically shutdown. I plug the magsafe back in and it boots up. Sometimes I do notice it can get down to below 20% and then shut down. What do you guys think? A battery or logic board problem? Thank you in advance for your help!
Es esta una buena pregunta?
Puntuación 3
1 comentario
Had a similar issue when unplugged at 55%. It was fixed by resetting with:
https://apple.stackexchange.com/question...
Take anything you read with a grain of salt.
- de
Agregar un comentario
2 Respuestas
Solución Elegida
@boogiexl ,Eddie. Checked a couple forums and found this, Link 1,2 You can try a battery calibration or Link 3 Reset Mac SMC (System Management Controller) use this reset when experiencing power management and battery problems: Mac isn’t turning on, sleep isn’t working, random shutdowns and reboots, battery isn’t charging, Good luck.
http://www.makeuseof.com/tag/calibrate-m...
http://www.tomsguide.com/faq/id-2349626/...
http://osxdaily.com/2010/03/24/when-and-...
https://support.apple.com/en-ca/HT201295
Fue útil esta respuesta?
Puntuación 2
As stated above, try a SMC Reset. If there is no change. Try reinstalling your OS and Verifying all Updates are applied. If issues still occur, have an Apple store or service provider run a MRI test, there is chance that the battery is not below the FFC % yet still causing shutdown like failure.
Good Luck,
Henri
Lead Service Technician
MacSuperStore, Santa Barbara
Puntuación 0
Añadir tu respuesta
Eddie Bugayong Jr estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 12
Ultimos 30 días: 16
Todo El Tiempo: 18,827
